How risky is it to replace iPhone 13 mini back glass
Just wanna know might be doing a replacement
Hi
This repair is only risky if you don’t know what you are doing!
This repair is safe as long as you do the following:
-fully remove all components from the housing to prevent damage
-use the correct equipment EG:pry tool and hot air station or laser
-cover and protect your camera lenses
-Be careful and take your take your time as this repair isn’t easy
Hopefully this helps
Any questions please ask
Hi also just wanna know what glue to use putting the new back glass on
@Pizzaconnor 11
I would use some form of liquid adhesive that’s strong:-)
Any specific glues
@Pizzaconnor 11
I have heard that B7000 is good for it:-)
Ok thank you
After using a laser to remove a back glass there’s not a cat in hells chance I’d attempt it with hot air. UNLESS it’s been replaced before. Don’t bother watching YouTube videos as it’s not the original glass they’re removing as they are made to look easy. (Hence phones getting damaged by people thinking it’s easy) As said before, if you are going to try it then go easy and don’t force anything. You’d be better having a punch for around the camera lenses and a set of replacement mag safe magnets as they will come off and probably pull some coils off the wireless charger too. You might also rip the cable for the rear flash too.
Not being negative or trying to put you off. Just being honest about what could happen.
Good luck with it.
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 150
All Time: 3,666
