Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
482 Questions View all
Replacing iPhone earpiece speaker; lost a Phillips screw. Will it work
I was replacing my iPhone 11 earpiece speaker and I lost a Phillips screw that holds the assembly inside the phone. Will the speaker still work or will it have issues if only 1 screw is missing from the assembly?
Score 2
Add a comment
Most Helpful Answer
Hi
I think it will work fine as the speaker has separate connections and doesn’t use the screws for anything apart from holding itself to screen
I would replace it if given the chance though but it should work without it
Hopefully this helps
Any questions please ask
Score 1
Add a comment
It will most likely work, but if you are worried about it you could try to find a replacement screw. You can buy the sets of all the screws on eBay and a bunch of other places. Also make sure you replace the water proof seal when you finish the repair.
Score 1
Add a comment
Add your answer
Juan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 134
