Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
167 Questions View all
Are iPhones Still Water Resistant After Replacing Their Camera Glass?
I just replaced a cracked camera lens glass on my IPhone 12, will it still be water resistant after putting a new lens on? If not, is there anything I can do to make it water resistant again?
Add a comment
Most Helpful Answer
With all due respect, I'm going to mostly disagree with Ben. Supposedly anything you do that affects any adhesive on the phone means it loses it waterproofing bona fides. However, done correctly, adhesive replacement can get the phone close to where it originally was with regard to water resistance.
I would personally be fine with the adhesive that comes with replacement camera lens glass, but if you want to up your feeling of security, you might consider placing the adhesive down, then run a very thin bead of silicone sealant around the outside edge of the adhesive. I'm talking about like the diameter of a pin, maybe a pencil lead, max. You definitely don't want enough in there that it could squeegee across the glue and get on the lens.
One thing to keep in mind is that with a crack in the glass it's definitely not waterproof! So anything you do to replace the glass is only going to help.
Score 2
Add a comment
No, as it says here: https://www.bing.com/search?q=Are+iPhone...
Score 1
Add a comment
Unfortunately not, but i would recommend u to use camera lens protector that would make your phone a bit water resistant
Add a comment
Add your answer
Max Leavitt will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 63
All Time: 2,360
