Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
156 Questions View all
iPhone 11 Pro NFC not working
Fixed an 11 Pro, changed full housing with an other 11 Pro, and sold it.. The only parts not changed are the motherboard, FaceID parts and the Taptic Engine... Everything worked while testing ( i couldn't test NFC ). Now the buyer says his NFC doesn't work. He broke the back glass so I will be charging him, where or wich one is the antenna for the NFC or what parts work together to make it work?
Please answer ASAP ( with pictures ), he wants me to repair his back glass so I will be doing a full housing repair ( keeping the same parts ), + new antenna('s) for NFC
Thanks
Add a comment
Why is my NFC not working on iPhone?
It’s possible that even if an Apple Pay-ready terminal will work with your phone, its NFC reader hasn’t properly detected Apple Pay. If you find that simply holding your phone up to the terminal doesn’t work, try selecting a card manually. To do this, go into the Wallet app, then select the card you want to use.
How do I turn on NFC on my iPhone XS?
First open the Settings app on your iPhone.
Then select the option “Control Center”.
Scroll down and tap the green plus button to the left of “NFC Tag Reader”.
Regards,
Will
Add a comment
The NFC antenna feed is around the rear camera housing from top bezel to one of the screw posts for the logic board. Check if you forgot to transplant all the flex cables and the metal clips over to the new housing and assembled them correctly.
You supply pictures, I'm too lazy to upload pictures for a free answer.
2 Comments:
With the 11 Pro you have no antenna around the camera, its like only 3 antennas in the whole phone... What else could cause the problem?
by
@vosjary Yes you have, you are not looking carefully enough.
by
Add a comment
I looked after the nfc thing in the settings>control centre but i didn’t find the nfc there, what could be the problem?
1 Comment:
Thanks for answering me, in the mean time the phone has been fixed. I had torn off a small piece of the nfc cable so that’s why it didn’t work, I replaced it and it’s working like new now!
by
Add a comment
Add your answer
Jary vos will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 109
All Time: 6,067
