Repair documentation for the updated Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1A
26 Questions View all
Pressing the X button presses also the PS button! Please read below
When I press the X button, the PS button acts like it's pressed plus the controller doesn't turn off.
The controller works perfectly besides from that!
Tried resetting the controller didn't work. Tried cleaning the surface and get some isopropyl alcohol under the X-button, didn't do it correctly but still the controller didn't work.
Called some local repair shops, some responded that I just throw it in the garbage.
What might be the problem? What might be the cause? and how to fixit?
The controller is new (2 months old) I'm out of the US before suggesting warranty replacement.
Update (4/8/2023): It is fixed!
Thank you all for help! Just checked as you guys suggested the conductive film (the green/blue board underneath the buttons), Cleaned it with cotton soaked with isopropyl alcohol, now it works again!
This is a YT tutorial
Add a comment
Chosen Solution
I’d say it be a problem with the membranes or the contacts on the board it’s self in sorry that the stores are telling you to throw it away never do that the reason I think they said that is because the controller is kinda infamous for being hard to repair
Score 2
7 Comments:
So do I just disassemble it and clean underneath?
by
I would say to yes sorry for the late answer but be careful k
by
Dont worry, follow this guide. 100% it will be okay.
The problem is in the circuit board. The little green/blue board flex which has the circuit lines.
Simply remove the inner black case and then turn it upside down there you will see the board flex. Then replace it
by
@mondelegend Thanks a TON!!! I didn't replace it, just cleaned the board flex with isopropyl alcohol (put a drop on a cotton and passed it through the circuit lines and these black circular thingies that lie under each button), it worked like charm!!
by
It's a late thanks to you for pointing it out, just disassembled the controller and cleaned the board with isopropyl alcohol, no problems at all!
by
Show 2 more comments
Add a comment
Is there any other way besides taking it apart with screwdrivers?
Add a comment
Add your answer
Moe hamm will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 195
Past 30 Days: 932
All Time: 8,639
