The Hoover Carpet Basics Power Scrub Deluxe Power Cleaner can be identified by its model number: FH50150. This upright power cleaner was originally released in 2014.
7 Questions View all
Why are my brushes not moving on my hoover cleaner
1 Comment:
Reviewed sidebar questions? There may be a belt drive, damaged or broken from a jam. A full parts diagram would help you determine if a belt drive is used or motor. If motor driven, checking for damage for overloading may require a multimeter to check for voltage to the motor.
by
Add a comment
1 Answer
Most likely the drive belt for the brushes is broken or the bearings in each end of the roller drum are seized.
Add a comment
Add your answer
Conley Snyder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 259
