Model A1051 / 4 or 6 GB hard drive
90 Questions View all
Is there a way to fix my click wheel?
Only two days ago I replaced my 1st gen mini’s battery and when I went to pause a song the button did not work. This is the only button to do this and it’s a pain to not be able to stop a song at times. Is there a way to fix it? (Preferably not paying for another part)
Add a comment
1 Answer
Most Helpful Answer
Hi Cheezus,
Since you have to disconnect the entire click wheel to replace the battery, my guess would be that the connector isn't fully seated so you're getting most of the buttons working except one. I'd open up the bottom of the case again and reseat that plug. Pop it off and check for bent pins, then it wouldn't hurt to clean both sides of the connector with 90%+ isopropyl alcohol and reassemble. You can test it before you put it back together to verify if it's fixed or not.
Score 1
Add a comment
Add your answer
Cheezus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 168
