Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
62 Questions View all
Piston number 2 is misfiring
Hi. I have a problem.
My opel Astra G 1.6 16V has a problem, piston number 2 is not burning fuel/ gas. Whenever i test spark.. It's there, but the plug is covered in gas. What could be the problem. How do I fix it.
Add a comment
1 Answer
Most Helpful Answer
Hi Chris,
How are you testing the spark? If the spark plug is working, it shouldn't be soaked in gas, obviously. If you're pulling the wire off the plug and verifying you've got spark at the end of the spark plug wire, that doesn't guarantee the spark is getting through the plug into the combustion chamber. Remove the spark plug from the cylinder and plug it into the plug wire then ground the threads against the block and crank the engine over. You should see spark between the electrode and the tip of the plug. If you don't see any spark, try swapping the plug with another cylinder and see if the misfire follows the plug. If that happens, you've got a spark plug that's damaged internally and not conducting the spark from the wire to the electrode.
If you do get spark and the misfire stays on cylinder 2, the next step would be to do a compression test. Without compression only a small amount of the fuel/air mixture is going to be present on the compression stroke and not much is going to happen when it sparks.
Try those things and let us know what happens; if you have a good plug and good compression we'll try and figure out what to do next.
Score 1
Add a comment
Add your answer
Chris Malaza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 88
