Intel's Skull Canyon generation of the gaming-focused NUC line.
3 Questions View all
Question identifiying SMD Component - Capacitor?
Hello everyone, I have a question that I posted on Reddit and got a few contradicting answers. I purchased this Intel NUC6i7KYK as "Parts" on eBay because it was power cycling. I originally thought it just needed some cleaning and new Thermal Paste, but that is not the case. I was looking at the bottom of the board, and found what I believe to be a blown capacitor. I attached a stock picture, and circled the component in blue. I know it is impossible to identify the exact specs of this part, but at least knowing what type of part it is will point me in a direction to troubleshoot. Since the board is dead, I really have nothing to lose by trying to fix it and learn from it. According to Reddit, it is either a fuse, capacitor or resistor. One suggestion would be to put a 0ohm resistor in and try it, but I don't want to do that if it is actually a capacitor. Thank you in advance!
Score 1
Add a comment
1 Answer
Chosen Solution
Looks like a resistor, the caps are a browny colour. I’d try and find a resistor the same dimensions and try it. Remove it from the board first and see if there’s any measurement across it. I’d also check for a bad mosfet.
Score 2
1 Comment:
Perfect, thank you very much for the quick reply!
by
Add a comment
Add your answer
Likwid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 239
