A high end laptop, made from Aluminum and Carbon fibre chassis, that Dell manufactured in 2018.
10 Questions View all
New 97w Battery Replacement - Not charging past 47%
Purchased a new battery to replace my current Dell branded 97w battery. The replacement was easy, however the battery is not charging past 47% (first time) and left on over night 18 hours. I did reseat again with not luck. Also, upon removal I performed that CMOS "flea" power clear holding down the power after battery removed for about a minute. Also, thinking this battery might actually be just a little thicker than original a I'm not getting a true click motion on my touchpad. Will most likely return and get a Dell original but thought I would ask here first. Really like what this company is doing and would prefer doing business here.
Add a comment
1 Answer
Chosen Solution
Hi,
Create a battery report and compare the Design Capacity value versus the Full Charge capacity value.
For a new good battery they should nearly be the same value.
You may just have got a bad battery.
There is a 1 year warranty on the battery so if it is faulty getting a replacement should be no problem. Also explain about the "thickness" and the problem you think it caused. They may have got a bad batch who knows?
Score 1
Add a comment
Add your answer
Mark Willis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 131
