Where is the electronic brake control module located on a 2004 Chevy s
Where is the electronic brake control module located on a 2004 Chevy suburban
The Electronic Brake Control Module (EBCM) on a 2004 Chevy Suburban is located in the engine compartment, on the driver's side, near the brake fluid reservoir. It is mounted on the Brake Pressure Modulator Valve (BPMV) assembly, which is connected to the brake master cylinder.
To locate the EBCM, you can follow the brake lines from the brake master cylinder down to the BPMV. The EBCM is attached to the BPMV with several bolts, and it has a large electrical connector and brake lines connected to it.
It's important to note that the EBCM should only be serviced by a qualified technician with the proper tools and training. Working with the brake system can be dangerous, so it's recommended to have a professional mechanic inspect and repair the EBCM or any other brake system components.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 48
All Time: 936
