Will not detect or read and SD card
It just keeps reading SD card error
Hi
Sometimes cleaning the SD card slot with some isopropyl alcohol and a toothbrush can help to resolve this issue
Also the Hero 5 was known for the water resistance being a bit of a hit or a miss so if it has been exposed to water I would recommend using this guide to check the device for water damage
Here’s a disassembly guide
GoPro Hero5 Black Motherboard Replacement
Once again isopropyl alcohol is good at cleaning corrosion but water damage can sometimes need professional work
I would also check the formatting of the SD Card,make sure the GoPro can read it:-)
Hopefully this helps
Any questions please ask
Try another SD card before you get to the point of disassembly, i've had some SD cards fail in odd ways like that before!
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 107
