Repair and disassembly guides for Lexmark printers.
19 Questions View all
Is my yellow toner at risk of leaking?
I had to replace my cyan and magenta toners for the same issue as can be seen here. I do not have a photo of the yellow toner but it's basically doing the same thing. I have a new yellow toner on hand but this one still has a bit of life left, the others were too close to not call it.
Is this leak worrisome to the point it's probably time to replace the yellow as well?
Score 1
Add a comment
Chosen Solution
Ended up needing to replace yellow too :/. It got to that point as well.
Score 1
Add a comment
Most Helpful Answer
Laser toners do shed a bit of toner through use. I wouldn’t call it a leak exactly. I used to sometimes wear gloves because the cartridges were covered in powder. Depending on levels you’re probably better changing them as a set then hopefully they’ll all need replaced at the same time.
Score 1
2 Comments:
I'm changing them as I go, not as a set. The black is still fine
by
My concern was the severity of it; I honestly expect a little bit, but this was bad. The waste toner on the cartridge was full.
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 111
