Information and repair instructions for Danby Freezer
2 Questions View all
Do I have a freezer thermostat issue?
Hi everyone,
Looking for some help here. I have a Danby stand up freezer that just completely goes warm and dead on me. However if I play with the thermostat the motor kicks in. So I'm thinking it's the thermostat that needs to be changed. However i tested the thermostat for continuity and it's seem fine. Any suggestions? Can it be a defective thermostat despite having continuity?
Update (04/05/23)
I meant Tested the thermostat.
Score 1
6 Comments
Hi @uvfvb50vflmba,
What is the model number of the freezer?
by
@jayeff The model is a Danby DUF808WE.
by
Did replacing the thermostat fix your issue? I'm having the same problem with the same model freezer. Have a thermostat and start relay on order.
by
Hi Marco,
I have the same model Danby WUF808WE, what screwdriver did you use to take the thermostat cover off with? Seems to be a special type and I can’t seem to locate one.
Cheers,
AJ
by
Hi Marco,
Cheers,
AJ
by
Show 1 more comment
Add a comment
Most Helpful Answer
Hi @uvfvb50vflmba
Manually getting a thermostat to operate/release may be different to if it does it automatically so to speak.
By "...if I play with the thermostat the motor kicks in." you mean just tapping it then replacing the thermostat might be a good idea.
The Danby part # is 1.03.02.01.070. If you search online for Danby 1.03.02.01.070 you will get results for suppliers. Most say out of stock or no longer available, although depending on your location, I did find a Canadian supplier who has them in stock and also a US supplier who can get one by early May.
If you need more parts here's the parts list for the model.
Score 2
1 Comment:
Agreed. If messing with the thermostat gets it to start cooling again, the thermostat is failing. At this stage it is intermittent. Soon it will stop altogether. Recommend replacing tstat.
by
Add a comment
Hi @uvfvb50vflmba,
Without knowing the model number or other details. It sounds more likely a connectivity issue, unless it uses a very old thermostat that contains mercury. For example a cold or bad solder joint or frayed wire.
1 Comment:
Oh right very sorry about that.
The model is a Danby DUF808WE. Its about 10 years old.
Thank you
by
Add a comment
My Danby is about 30 years old. It stopped working until I moved the thermostat to 1 or 0. The thermostat had broken off from one of its mounting screws about an inch from the top of its mount. I have since repositioned the thermostat with rubber caulking and it has been working fine for over a week now. Does anyone know if the thermostat is probably a mercury type?
1 Comment:
Hi @lenjeffrey,
You would have to contact the manufacturer of the thermostat to know for sure.
The type of thermostat that has a long thin tube inserted into the cabinet could have the tube filled with either a liquid or a gas.
There's a temperature sensor connected to the tube in the main body of the thermostat. Essentially the tube just relays the temperature from the compartment through to the sensor.
The sensor has a set of contacts that controls whether the compressor is turned on or off to either cool the refrigerator down or to stop cooling as it is cold enough.
by
Add a comment
Add your answer
marco.cascini78 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 107
