I have a check engine light? the code I have is a p2716.
how can i fix this. what should i look for when trying to diagnose the problem
@juliogonza20517 the best with any of these codes is to proeprly investigate. I am sure that by now you know the code standas for
P2716 Toyota Code - Pressure Control Solenoid 'D' Electrical
Code P2716 Possible Causes:
Low transmission fluid level
Dirty transmission fluid
Faulty Pressure Control Solenoid 'D' valve (Shift Solenoid Valve SLT)
Pressure Control Solenoid 'D' valve harness is open or shorted
Pressure Control Solenoid 'D' valve circuit poor electrical connection
Faulty Engine Control Module (ECM)
From here The best is to checks with those that have dealt with the error. Definitely check on here for some really good explanations.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 128
