Repair documentation for the updated Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1A
26 Questions View all
Problem with drifting (Replaced joy with ElecGear EL7 FU 2.3K)
Hey guys, so... i bought a new controller for my daughter with drifting and tried to fix it, i bought some joysticks from amazon (ElecGear EL7 FU 2.3K) and replaced it, but now i got like if i were moving the stick left-up all the time, like if the resistance of the joystick wasn't working, any advice to check? probably i bought the wrong replacement? thanks in advance.
Update (06/06/23)
Yeah, i realized that was sticked on the sided of the box that they came in, however it was entirely my fault, sometimes when i cannot desolder some holes in the pcb i tend to drill with a bit to clear the hole (will never do that again, lesson learned) so i broke the connection between down side of the pcb with the top side (didn't knew that they had to contact both sides) so after a lot of troubleshooting i linked both sides with a little copper wire and now its working, had to install calibrators also tho.
Score 1
Add a comment
1 Answer
Did you also soldered the little included Drift Fix PCBs with the resistor on it? This allows you to calibrate them to nearly perfect 0 on all axis when the case is still open and the controller connected to https://gamepad-tester.com/. Looks like this then: https://imgur.com/a/1s7uJfd
Add a comment
Add your answer
Jorge Rua will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 754
