Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
167 Questions View all
iPhone 11 12 13 Spot Welding Battery = 0 Volts
I just got in a spot welder to replace a battery on my first Iphone 11 this week.
After spot welding the output voltage was 0.
_________________________
Now I have 2 broken Iphone 12's
Same issue happened, I went to spot weld the Flex onto battery and then 0 Volts on the output...
Thanks
Kevin
Score 1
5 Comments
there is a solder out now that you can use for soldering the bms, maybe you should try that to see if you have better results
by
@tech_ni Thanks, with a quick search i dont see bms solder. I do have Kester solder though which is premium solder.
Perhaps its just not making a connection. I guess i should try to sand or scuff the surface before attaching. I notice the tabs are laminated and can prevent conductivity..
by
@tech_ni
@4min. 0 volts is normal... i will have to test this.
https://youtu.be/rdIjopmCmRw
by
@willie604 looks like the battery just needs activated
by
Add a comment
Chosen Solution
I found the answer here...
After he solders the bms at 4min, the battery voltage reads 0V. He says this is normal.
You need to plug the phone it for it to come to life.
It was fine all along....
Score 1
Add a comment
Most Helpful Answer
Hi
Me personally iv never done the whole spotwelding battery’s thing so apologies if this isn’t any help
What I do is solder onto the terminals as I would imagine it isn’t as aggressive to the BMS or the battery
Not much solder is needed just enough to make it strong but still low profile
Hopefully this helps
Any questions please ask
Score 1
4 Comments:
Hello,
I found something interesting in this video. He shows 0v is normal after attaching a bms
Also i didnt realize that the tab on the bms can be unsoldered
by
@willie604
That’s interesting
Those tabs can be unsoldered if you use high temps :400-450 deg c
by
@hellomacos Everythin was fine. The battery just needed to get plugged in and activated!!
by
@willie604 That’s great to hear!
by
Add a comment
Add your answer
Kevin W will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 42
All Time: 488
