This printer is a more expensive upgrade from the Ender 3, with bigger knobs, a new toolbox, and a "brand new user interface" among other things.
4 Questions View all
after the gcode file is taken by the sim card the printer not printing
the file was in sim card and the 3d printer was shown the file but when i click on it it is no doing it imdly so i have to wait for a while or it should imdly work on it.
Add a comment
The printer waits till all the heated parts are up to the programmed temperature before the print starts.
Hope this helps.
Add a comment
make sure you have installed the proper firmware on the motherboard via the SD card.
Don't be a muppet, get the download straight from creality.
If that doesn't work, then if you are using a 4.2.7 motherboard, make sure your UI is the new touchscreen one.
If its a 4.2.2 then you should be fine
Add a comment
Add your answer
cdsc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 47
