How do I reset security?
car disabled because of security
Is the security light flashing when you try to start the car? If so, try performing a "Passlock Relearn":
Some things to note:
Yes thank you for your information I am away from My books mastermechanic037@gmail.com
I can’t get my 2004 Pontiac grand prize to start it was disabled due to theft started l tried the 3 cycle 10 min 5 second thing still wont start I got the security light in dash near windshield to flash again now what will it start when I put key back in ignition
I tried the 10 min thing but at that time the light wasn’t flashing in dash but module above center console says disabled due to theft system can I disconnect positive and negative cable for a period of time reconnect them and then be able to start car normally
Any help would be appreciated
Mines doing the same things I tried everything they said and it's still doing the same thing help please
Anyone else figure it out I have the same problem tried the on position for 10 minutes thing still didn't work help please
Please don't assume anyone knows what you're driving. Make, model, year, if GM - is your factory antitheft Passlock or PassKey? Is there an aftermarket alarm system?
Past 24 Hours: 4
Past 7 Days: 63
Past 30 Days: 276
All Time: 3,136
Is security Passlock or Passkey? Do you have an owner's manual?
by F Dryer
It's like body control module not picking up the key but it is intermittent
by Monty
