HP's expandable, RPN-based graphing calculator. Manufactured from 1990 until 2003.
23 Questions View all
The metal came apart from the foam in the battery compartment
The metal has come off the foam in the battery compartment. I used adhesive glue to bind the two together but every time I put batteries in it the metal detached from the foam. Any help would be appreciated.
Score 2
1 Comment
@annebrown5801 Can you upload a picture or video of the problem? Adding images to an existing question
by
Add a comment
1 Answer
Most Helpful Answer
@annebrown5801 To me, the best solution would be to get double-sided self-adhesive foam of the same thickness, remove the old foam (and any residue), and reinstall the new foam. You can then remove any adhesive residue on the battery contacts and stick them to the other side of adhesive on the foam.
The residue can probably be removed with soap and water, however, you will need to take the calculator apart to make sure that no water gets into the calculator while cleaning the residue off.
If you can't find double-sided self-adhesive foam of the correct thickness, you may be able to layer multiple pieces of the self-adhesive foam to get a piece of the correct thickness.
Let me know if you have any questions or need links to buy the products mentioned.
Score 1
Add a comment
Add your answer
Anne Brown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 55
