Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
22 Questions View all
14 pro restarting randomly SMC PANIC - ASSERTION FAILED - BSC failure
14 pro randomly crashin and restarting , below is log
{"bug_type":"210","timestamp":"1969-12-31 16:11:18.00 -0800","os_version":"iPhone OS 16.5.1 (20F75)","roots_installed":0,"incident_id":"D97AD64D-EAF1-4524-A740-867851D18C24"}
"build" : "iPhone OS 16.5.1 (20F75)",
"product" : "iPhone15,2",
"socId" : "8120",
"socRevision" : "11",
"incident" : "D97AD64D-EAF1-4524-A740-867851D18C24",
"crashReporterKey" : "5708cca0163b1c9b29d59baa119fc997ba2e3190",
"kernel" : "Darwin Kernel Version 22.5.0: Thu Jun 8 17:15:47 PDT 2023; root:xnu-8796.122.5~1\/RELEASE_ARM64_T8120",
"date" : "1969-12-31 16:11:17.01 -0800",
"panicString" : "panic(cpu 0 caller 0xfffffff017bf04ac): SMC PANIC - ASSERTION FAILED: target\/d73\/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 130\nS.sensor array 0 - 4 is 0x0, 0x80000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d73\/target.cpp:265: 0, SMC BSC failure, spreadsheet ver(*10) 130\nS.sensor array 0 - 4 is 0x0, 0x80000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2062.122.2.release - Client: AppleSMCFirmware-3424.120.39.0.1.d73.REL\n!UUID:
Full log : https://pastebin.pl/view/5e3a972d
Score 1
2 Comments
Hey! My iPhone 14 pro max got into water and I am facing the same issue. Did you managed to fix it chaging any part? Any flex? Or disconnecting something? Thanks!
by
Hi, the solution is to change proximity sensor.
by
Add a comment
Chosen Solution
@flannelist Alisha, looking at this panic I see that the sensor code it's calling out is numbered 0x80000, which I assume is not the same as the 0x800 for the charge port assembly. It looks like they've got a 32 bit word and each bit turned on corresponds to an individual sensor, but at this point it doesn't look like we have any information on which sensor 0x80000 is.
Any idea where we could look for this information?
Update (06/30/23)
Okay, some news here; it looks like @tech_ni is on the right track here; according to repair.wiki, here's the definition for that sensor.
Alisha, maybe something to add to your Wiki page?
Update (06/30/23)
Ah, I see what's going on now. Repair.Wiki has codes for the iPhone 13 and 14, and it turns out the same problem has a different code on the two models. That's going to be fun to keep up with in the future.
Alisha, I've edited your Wiki to add that latest information; feel free to modify, accept or reject my changes as you feel appropriate.
Score 3
5 Comments:
@dadibrokeit THANKS I have been meaning to get around to that. I know the codes for 14 Series are different just wasn't sure if that had been sussed out yet. I know Jesse Cruz stays busy keeping a lot of the repair.wiki stuff up to date, so I would trust whatever is there.
by
Everything worked as advised once sensor is changed. Thanks
by
Which sensor did you change
by
@tapiwabynergy This entire thread has been about the proximity sensor, so I'm going to go with that.
iPhone 14 Pro Front Sensor Cable
by
FAILED: target\/d28\target.cpp:266: 0, SMC BSC failure, spreadsheet ver (*10)
40\nS.sensor array 0 - 4 is 0x0, 0x600000,
Pls does anyone has soln to this?
by
Add a comment
disconnect the proximity sensor and see if it changes
Score 1
10 Comments:
when i disonnected proximity sensor and attached , sensor got very hot and the plastic white thing got seperated. now i have to buy new sensor to see if that survives.
by
@manikanta9463 going by panic full analyses its to do with the proximity sensor
by
@manikanta9463 i edited your post and added the screenshot of panic full diagnosis
by
@manikanta9463 your date is showing decades of iphone release aswell
by
I will get new proximity sensor and check if its fixes the issue. but without proximity sensor , still the device is rebotting , is it common ?
by
Show 5 more comments
Add a comment
Had the same issue with an iPhone 14 Pro Max (same panic.full error)
The iPhone had been severely damaged after the customer dropped it. We got a new screen for it and mounted that, instead of the broken one and we couldn't understand why it kept overheating and shutting down, whilst providing us this error.
Turns out it happened because the front sensor wasn't connected. :) (Turns out it's quite important, even if you only want to pull out data from the iPhone.)
Now the data is out safe and sound!
Score 1
Add a comment
Add your answer
Mani will be eternally grateful.
Past 24 Hours: 31
Past 7 Days: 329
Past 30 Days: 1,307
All Time: 10,885
