Marshall Stockwell Bluetooth speaker
5 Questions View all
Can I use my Marshall Stockwell without the battery?
The battery on my Marshall Stockwell does not retain charge anymore. I removed it and i will refurbished it with a company that dedicates to this. Can i use it without the battery in the meantime?
Update (07/02/23)
After posting this question here, I contacted Marshall through their chat support.
They told me that removing the battery and using the speaker connected to the power supply charger would not cause any damage.
I decided to give it a try, and I'm happy to report that it works perfectly.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Check first your power supply if it still working.
  • Remove connecting terminal of your battery and check the positive and negative terminal wires if there's still voltage output. I yes, may your battery was already damaged (Replace it). If no voltage output or has a lower voltage output, replace your power supply battery charger.
  • If you want to use it without the battery anymore, you can use a power supply that has the same voltage/current rating to your charger/battery. Connect the power supply directly to the battery terminals after removing the battery.
I hope it can help.
Score 2
1 Comment:
Thanks for your reply, James!
by
Add a comment
Add your answer
Fokka85 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 69
All Time: 386
