This machine will automatically cook hard, soft, and medium boiled eggs, as well as poached eggs.
2 Questions View all
Will not turn on
I’ve just purchased a new/old stock unit, but when plugged in and the button is pushed, it does not light and no heat is generated. The unit is fairly simple; where should I begin to troubleshoot? Line cord continuity?
Score 1
Add a comment
1 Answer
@clarknovak58364 start opening the unit up (unplug it first) measure the continuity of the power cord. Then check the switch and next check the heating coil. You need an ohmmeter for the heating coil and measure the resistance of it. Let us know what you find out. Use this guide to work on it Oster Designer Egg Cooker and Poacher Disassembly
Post some pictures of your unit if you are stuck, or if you find something that looks odd, That way we can see what you see. Adding images to an existing question
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Oster Designer Egg Cooker and Poacher Image
Guide
Difficulty:
Easy
20 minutes
Add a comment
Add your answer
Clark Novak will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 33
All Time: 127
