The Ford Explorer and the Mercury Mountaineer were both updated for the 2006 model year on a new frame, produced by Magna International rather than Tower Automotive.
25 Questions View all
Why rpm jumps during accelaretion between 25mph to 60mph
Hello friends
I have explorer 2009
During idle the rpm is constant
During accelaretion from 0mph to 25mph the engine is smooth
During acceleration from 25mph to 60mph, when I'm in 1500-1400 rpm, it jumps to 1800rpm with rrrrr noise and go down back to 1500rpm.
Its happened several times until I reach 60mph, and then the car drives smoothly.
If I will accelarete with higher rpm, 2000rpm or more, the rpm jumping doesn't accure
What is the cause?
Please help
Thanks
Score 1
Add a comment
1 Answer
Most Helpful Answer
I'm guessing your descriptions of your xmission is it's downshifting for the jump in rpm. There may be more than one issue here; replacing xmission fluid as recommended in owner's manual, shift linkage adjustment and/or electronics controlling shifts that may need a program update (usually free from manufacturers). I think you can check online if there are any service bulletins related to xmission software updates from the manufacturer.
Score 1
Add a comment
Add your answer
Guy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 60
