Gateway GM5478. I hear a lot of beeps than it shuts down
I hear a lot of beeps than it shuts down. It’s a gateway GM5478.
Hi @alibubbba
Count the number of beeps that uyou hear before the pC shuts down.
Here's a list that details what each beep count means.
Post back here with the number and we'' help you further to try and fix it
3 beeps so I have to reset the memory module. Do you think this might be the reason why it’s not producing an image?
If there's a memory problem then the laptop is most probably failing POST (power on self test) and not even fully starting, therefore no display
When the laptop is started it does a self test of the hardware before booting into Windows (which is software) to make sure that most of the hardware is working OK e.g. memory, video, CPU, fan BIOS etc.
If there's a problem it gives a series of beeps to tell the user what the problem may be
Remove/disconnect the battery from the laptop before reseating the memory module as you don't want to cause any more problems.
If reseating the module doesn't fix the problem, you may have to replace it
@jayeff I just bought new sticks. I’ll I install them and let you know. Current the desktop has Nanya NT1GT64U8HB0BY
New ones just bought
Crucial RAM 16GB Kit (2x8GB) DDR4 3200MHz CL22 (or 2933MHz or 2666MHz) Desktop Memory CT2K8G4DFRA32A
I just took out one of the sticks and put it back in and started up the desktop, and it gave me no beeps.
Although I’ve been doing that, and it hasn’t worked.
It won't work with the new memory you bought.
The PC only supports DDR2-667 ram PC5300 (and possibly DDR3 memory but depends on chipset used) and not DDR4 ram as you have tried to use.
See the specifications
The PC is showing its age.
Memory compatibility is determined by the CPU and the chipset on the motherboard
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 101
2 Comments
@jayeff
Ah I see. What do you suggest I do? I just want to repurpose the PC to be server test environment.
by alibubbba
@jayeff
by alibubbba
