The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
77 Questions View all
What to do if the connector to the gas line and pump broke off?
I have a 2004 Ford Expidention that the fuel pump went out. I already changed the pump and hose to a new one. But when putting it back together the clasp that holds the gas line to the metal nosal broke and cannot find the right size for it and it keeps leaking gas.
Update (09/04/23)
I will try it out
Score 1
2 Comments
@brendaj65192 I wonder if you could replace it with a regular hose clamp. Post some good pictures of what this all looks like. Maybe we can come up with a fix for this. Edite your Question and use this guide Adding images to an existing question for that.
by
[image|3062446]
[image|3062447]
I will try it out
by
Add a comment
Chosen Solution
Use this hose clamp:
https://www.homedepot.com/p/Everbilt-1-2...
Score 1
Add a comment
@brendaj65192 those are quick connects and you would need a right angle one. Otherwise you will have to splice your fuel line and add an extend it to fit your fuel filter. Measure the thickness of the pipe sticking out of the filter. If it is 5/16 (8mm) use something like this. If it is a 3/8" (10mm) use this one
Score 1
Add a comment
Add your answer
Brenda J will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 57
