Gets power and fan spin. No POST
I recently acquired one of these workstations that I'm trying to get up and running. Here are the symptoms in case anyone has ideas, but I currently have it narrowed down to either the Power Supply, or the board.
- Turns on when you connect power. You do not need to press the power button. It just turns on.
- CPU, GPU, and PSU fans all spin. PSU will start to spin aggressively if left on for a while. (I don't remember if the memory fans spin; I took that assembly out so I could see).
- No video output. Can't try onboard graphics because it has a Xeon CPU. So no iGPU.
- No beep codes, blink codes, or other errors.
I would specifically like to know if the PSU is at fault (it's my current theory). Problem being. it's a proprietary power supply.
So. How do I test it? I am probably going to take the housing off and just look. But NOT TOUCH anything because I don't have a death wish. But I'm invested. And this is taking up residence in my brain.
PSU in Question. Specs/model number and weirdo connectors.
I'll probably cave and buy a new one, but I would rather be sure before I invest $$.
Stuff I have already tried. In case someone has other ideas that aren't Power Supply.
- Parsing down to minimum config (Only CPU, one stick of RAM)
- BIOS recovery
- Installing a known good GPU
- Remounting the CPU
- Swapping RAM sticks around (It has 8 slots. 3 were populated. I verified they were in the correct layout and tried various sticks in the Number 1 slot.
UPDATE 04.20.2024 - Somehow this thread keeps finding people and I have still not fixed this or found a definitive answer to my question, but hopefully these voltages will help someone, or at least contribute to this discussion. I should add, I do not believe these voltages are correct.
Measured voltages on my connector when both connectors are attached to the board and power on is attempted.
Colors are constent with typical markings
- Orange = 3.3V
- Red = 5V
- Yellow = 12V
- Black = Ground or Voltage measured
- Purple = 1V (I am not convinced this is normal, but nevertheless have nothing specific to compare to).
Even though my device powers on almost immediately after the PSU is connected to power, I can power off. Voltages with the power off.
Anything not marked has no voltage and all previously 12V lines have very nominal voltage (~.08V).
I am again starting to think the PSU is to blame. I have checked the board pretty thoroughly previously for shorts, but since it is a rather large board, this is somewhat difficult.
13 Comments
Thank you very much. It is a big help. Could you please measure the C12 as well with switched off and on state?
Some observations:
1. Good news: Pin 8 definitely is the PWR_STBY 5V.
2. PSU sticker is not mentioning 3.3V rail but you measure it on C18. I am a bit clueless on this. Could you measure C18 without connecting to the MB? Do you get 3.3V on P18 when the PSU is in standby?
3. P10 is the PWR_ON probably
4. P12 maybe the PWR_OK I am not sure.
Made some comment at the bottom as well.
Waiting for your answers!
by mita99
I believe the purple wire is the input to the PSU that turns it on - short green and purple. That is what the power switch does as seen here.
https://www.instructables.com/How-to-Tur...
As such, 1V is a floating input.
by bill
Hi Alisha,
Have you got the PSU? Any test results?
by mita99
this user had the same problem on multiple machines and hp changed the motherboards:
https://h30434.www3.hp.com/t5/Business-P...
by Simone Sacco
@simonesacco Thanks for reminding me of this. I have seen that post a few times over now, I stumbled into it originally when I first attempted to fix this device and I determined the motherboard was at fault.
I have since verified that it is in fact a board issue, but I am determined to find out what the specific fault is since I am not interested in replacing the whole board. And I am generally quite adept at fixing board level issues. I'll keep updating as I find more.
by Alisha C
Show 8 more comments
