Repair and disassembly information for the fifth-generation 12.9" iPad Pro featuring Apple's M1 SoC and an XDR mini-LED display.
27 Questions View all
Can I access ipad pro 2021 m1 with broken diplay by computer
my ipad pro 5th gen display totally smashed can't see anything and no budget to fix it , can i use it with pc or by attach it with monitor and usb mouse by adabtor cable without any kind of input in ipad to enable something in settings
Add a comment
1 Answer
Most Helpful Answer
iPads really need a working display as the interplay of the touch interface is difficult to navigate when looking at a different point. There is a noticeable lag which can effect your use.
With that, you can connect your iPad to an external display as you can see here Connect iPad to a display with a cable
This series uses a newer miniLED screen which is quite expensive and not presently available.
You might want to see if you took out AppleCare+ if Apple will cover the repair.
Score 1
Add a comment
Add your answer
Mohamed Salah will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 7
All Time: 34
