Repair and additional information for the GE Profile Refrigerator PFSS9PKY—a bottom freezer style refrigerator with an ice dispenser and dual access via a drawer and door, released in 2009. This page covers information for model numbers matching the pattern PFSS9PKY***.
2 Questions View all
Freezer not cooling down, Temp on front display shows -2,
The front display shows Freezer -2, Fridge 34. The fridge is at 34, checked with thermometer.
The Freezer is the same temp as the Fridge.
Would this be a sensor, since its reading the wrong temp?
2 Comments:
This is a PFSS9PKY Model
by
@dougriley I would start by checking the thermistor for the freezer. Try holding it tightly in your hand and seeing if the temperature changes on the screen. Alternatively, if you have a multimeter, you could hook the thermistor up to a multimeter and put the multimeter on ohms mode. When you hold the thermistor tightly with your hand, you should see the ohms reading on the multimeter go up or down.
by
Add a comment
1 Answer
Hi @dougriley
Here's how to find out if any error codes are stored in the refrigerator that may show what is not functioning correctly.
Enter the diagnostic mode > service diagnostics > self diagnostic test
Add a comment
Add your answer
Doug Riley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 34
