The Xiaomi Redmi 9 Prime was officially released on August 4, 2020 The smartphone is equipped with sensors such as a fingerprint sensor (rear-mounted), accelerometer, proximity, and compass. The smartphone features an Infrared port, USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go, and Bluetooth 5.0.
51 Questions View all
Phone screen is not waking after my phone got wet in rain
My phone got wet in rain and the display is not waking up. After holding the power button only a small vibration is felt but the phone is not waking up.
Add a comment
1 Answer
Most Helpful Answer
Hi Sarfaraz,
Unfortunately the LCD on phones are particularly sensitive to being exposed to water and have a nasty habit of dying unceremoniously when they get wet. It sure sounds like that's what's happened to your phone, I'm sorry to say.
You can try drying it out with a hair dryer, but if it's been a while since it got wet and nothing is getting any better, then it's most likely time to replace the screen. The fact that it is reacting when you press the power button is a good sign that the rest of the phone is still working even though the screen appears to have met it's end.
My best suggestion at this point would be to go ahead and replace the screen. While you have it open, check inside for any other sign of water; if there is any be sure and clean it out well with 90% or higher concentration of isopropyl alcohol to help eliminate the possibility of corrosion forming as a result of the impurities in the water.
I didn't find any written iFixit-style guides for your phone, but there's a YouTube video that looks like it has everything you need to be able to do the job.
Redmi 9 Prime Screen Display Combo Replacement
You shouldn't have any trouble locating a replacement screen; I'd suggest starting with places like Amazon, eBay and AliExpress, but there are many other sites out there that will carry them as well.
Good luck and let us know how it goes!
Score 1
Add a comment
Add your answer
Sarfaraz Memon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 32
