The larger, fourth-generation ES (designated MCV30) debuted in July 2001 for the 2002 model year.
11 Questions View all
acceleration gives out RPMs increase
what are the potential causes of the acceleration sporadically giving out (mainly with accelerating onto a highway) and the RPMs shooting up?
1 Comment:
Initial guess; low xmission oil, xmission pressure control solenoid(s), burned out clutch packs. Guessing is easy, diagnosing and troubleshooting requires familiarity with engines, EFI systems, electronically controlled xmissions.
by
Add a comment
1 Answer
It will do that if it is downshifting. If it is not, then something is slipping. Cause can be as simple as a problem with your transmission oil, or as complicated as a problem with the transmission itself.
Add a comment
Add your answer
David Hardy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 35
