The LG 25UM58-P is a 25" UltraWide LED Monitor designed by the LG Corporation.
2 Questions View all
Back light comes on but nothing shows on display
The back light comes on but shows nothing on display. I’ve tried different HDMI cables in different ports using different laptops.
It was working fine, then made a pop noise and stopped. When I try to use it, it makes a loud noise of a short while then stops.
Add a comment
1 Answer
Most Helpful Answer
Hi @lkethro
A loud pop sound is usually indicative of component failure.
Here's the ifixit LG 25UM58-P Teardown guide that may help.
Use it to disassmble the monitor so that you can check the mainboard for any damage.
If there is or you're not sure, post some close up images of the board back here to get further advice.
Here's how to add images to your question in ifixit Adding images to an existing question
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
LG 25UM58-P Image
Guide
Difficulty:
Moderate
45 minutes
Score 1
Add a comment
Add your answer
Lkethro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 89
