Find repair and further information for the Samsung RF24R7201 refrigerator—a 2019 large-capacity, non-compact model with automatic defrost and Wi-Fi connectivity. This page covers information for model numbers matching the pattern RF24R7201**.
1 Questions View all
Water dispenser works. ice maker does not work.
DOES THE ICE MAKER HAVE A DIFFERENT WATER INLET VALVE THAN
THE DISPENSER. good water pressure. no ice jams. no error codes after power recycle. no change after reset, expected to see ice or water in bucket,neither existed. where should I look for water inlet valve. I assume there will be one water inlet valve for the ice maker and a different one for the water dispenser.
Add a comment
1 Answer
Most Helpful Answer
Make sure the temperature in the ice maker compartment is 10 degrees or lower at all times, or it will not make ice properly.
If it is, you will need to replace the Ice Maker.
DA97-13718C - Samsung Refrigerator Ice Maker Image
Product
$126.99
Score 1
Add a comment
Add your answer
bjg will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 26
