My walker is bent
Walker went over with me in it when bus braked sharply it is now bent and goes left, is there anyway or anyone to fix it?
Score
0
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 26
The depends where the bend is but you can try to remove the wheel(s), insert a bending spring that corresponds to the diameter of the frame of your walker and try to bend it back. If you are not using a srping or something that you can insert into the hollow frame you will risk kinging the metal and woul will be worse off...
by honakrisi
