Will Not Start when power button pressed
When power button is pressed, green light turns on but sweeper will not start
Score
0
Finally figured it out…
Look inside the part that battery goes into and you will find 2 small holes on bottom ..
Use a small screwdriver in each hole and tighten screws well.
Put battery in and turn on ..it should work..if it stops and starts remove battery and try to tighten those 2 screws again
Good luck!
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 45
same thing happens with mine. It knows it is charged because when you plug it in for charging it flashes red then quickly realizes that the battery (voltage) is full. When you press the power button the green light comes on, but no reaction from the motor itself. When I have time, I will open it up and see.
by Eric L.
