Repair documentation for the updated Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1A
26 Questions View all
Headphone port removal and replacement
Hey does anyone have a video on how to remove and reinstall the headphone jack, I can see 4 solder points around it but my iron gets too close and just melt the plastics, same with the hot air gun. Any suggestions, thanks
Add a comment
1 Answer
Flux it, use "Low Melt" solder, and lower the temp on the iron. After a little time the port/jack should just fall out. Wick away the old solder, solder in the new jack using 60/40 leaded solder.
Wait......by "melts the plastics" do you mean the controller shell?? O_o
Always remove the board from the shell before hand. :)
1 Comment:
Hey thanks for the response. Not not the shell, I take the board completely out, I meant the headphone port plastic itself. I will try what you said. Thanks.
by
Add a comment
Add your answer
Jordan Shaw will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 17
All Time: 49
