Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
10 Questions View all
Record/playback only works when tape speed is set to 2.4cm
Everything seems to work just fine, albeit the audio sounds a bit wobbly, when the tape speed is set to 2.4cm. However, when i set the tape speed to 1.2cm, nothing works and only the battery light comes on.
Add a comment
1 Answer
Most Helpful Answer
Hi @isaakgilissen
Try replacing the drive belt.
Search online for Sony 3-377-420-11 to find suppliers that suit you best.
Also use some Isopropyl Alcohol 99%+ (available from electronics parts stores) to clean the capstan, pinch roller and the record, playback and erase heads in case they're creating a drag on the tape.
Here's the service manual that may help
Score 1
Add a comment
Add your answer
Isaak Gilissen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 39
