Repair, disassembly, and troubleshooting information for Apple's "smaller" 2023 flagship smartphone, released September 22nd. It features a 6.1" ProMotion OLED display, a triple-lens rear camera system, and 5G. Successor to the iPhone 14 Pro.
6 Questions View all
Screen unresponsive after water damage
I dropped my phone in the water yesterday it was only submerged for a couple of seconds and it was working after that. However, when I tried charging it I got the liquid detection alert. I left it to dry overnight and charged it...now the screen is unresponsive. Is there anything I do myself to fix it?
Add a comment
1 Answer
Most Helpful Answer
Hi @lisa85350
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 15 Pro repair guide that may help.
Here is the Repairing iPhone Liquid Damage guide that may also be of some use.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Add your answer
Lisa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 55
