Repair and disassembly information for JVC televisions.
10 Questions View all
White blotch growing over the screen and disappearing intermittently
Hi there, ive just come back from spending some time away and my JVC LT-50CF890(C) tv has started appearing this white wash over the screen that comes and goes irregularly.
If i unplug the tv and power on after a bit of time has passed, the tv runs fine for a couple of minutes before it returns.
If anyone has suggestions of what might be causing this id appreciate the help, was thinking it was maybe a faulty main board or tcon board but not sure, cant see any noticeable damage to the main board
Score 1
Add a comment
1 Answer
Chosen Solution
@bengray73588 that looks like a bad panel. Possible delamination or other panel error. Time to try and find a replacement panel. If you remove teh back cover, there will be a sticker on the sheetmetal back of the panel. That will have the manufacturer and model for your panel. Use that to do an online search . Even a broken TV same make and model as your (verify it has the same LCD panel) is acceptable for as long as it doesn't have a panel error. You can always try and harvest the panel from that.
Panels that size will cost you more on shipping etc. then a new TV will. That is the sad part on trying to repair issues like this.
Repair is War on Entropy!
Add a comment
Add your answer
Ben Gray will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 41
All Time: 122
