Repair documentation for the updated Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1A
26 Questions View all
I Swapped the Trigger and Bumper Ribbon Cables
I swapped the Trigger and Bumper Ribbon Cables with new ones and now the controller doesn't power on. If I disconnect one of the t&b cables (L1/L2) and leave the other one plugged in (R1/R2) the controller powers on and R2 and R1 work. I'm confused as to why this happens. Any help?
3 Comments
What if you disconnect the R1 & R2 cable? But leave the other one connected, does it still power on?
by
No it does not
by
Any solution??
by
Add a comment
1 Answer
Most Helpful Answer
Have you doublechecked that the triggers match up with the points on the controller responsible for registering input? If not do that.
There should also be a spring in the buttons. Is this connected correctly?
Score 1
Add a comment
Add your answer
Benji Customs will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 10
Past 30 Days: 15
All Time: 43
