Gear changing is very tight
When i change the gear it is very hard . It take 2-3 attempts to change it
@atif63383 I assume it's a manual transmission and you are having difficulties changing your gears while you are driving. If so, check you clutch first. After that you may have issues with your synchronizer, depends on if it is grinding the gears when you switch gears. Otherwise check your linkage to make sure things are properly routed.
For now, I'd suggest you look through this Swift Clutch And Transmission and see if you can narrow the issue down since it is a pretty broad topic
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 25
