Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
102 Questions View all
Touch ID not working, long button press needed to boot up
Hello y'all,
I own a MacBook Air 2019 with the Intel processor.
However, whenever I try to turn on my laptop I have to press the power button for a 10 seconds or so.
If I close my laptop without turning it off, I can't turn it on again and I have to manually shutdown and start via the power button. If I work on something and I close my laptop screen it won't be saved.
Touch ID doesn't work either.
Sometimes the keyboard backlight doesn't light up but that isn't the main issue.
Sometimes when I turn it on again I get this panic log: https://pastebin.com/DBcNQhY6
panic(cpu 1 caller 0xfffffff00d6982a8): "i2c1::_runInterruptMode Timed out waiting for interrupt;
Panicked task 0xffffffdf00545ff0: 0 pages, 200 threads: pid 0: kernel_task
Thanks for your help!
P.S.: I had to replace the audio board once, because it kept crashing. But I don't think that could cause the issue.
Update (05/01/24)
https://imgur.com/a/fq3nn5J battery seems to be alright...
i also checked the ssd with drivedx, not sure if its crucial but it seems to be alright. see https://imgur.com/a/JkbQ1h1
Add a comment
Most Helpful Answer
How about installing this gem of an app CoconutBattery and posting a snapshot of the apps main window here so we can see things.
From the sounds of it you have at least two issues! The systems battery and/or charging logic is not able to support enough power to suspend so your data gets lost.
The TouchID function may need to be setup again as it could be corrupted.
Panic's are not a good sign! 😖 You maybe hitting a storage space issue in your SSD.
Score 1
3 Comments:
@renax - your battery looks in reasonable shape. As far as the drive I’m wondering if the drive is just overly full. Go to About this Mac and look at storage, let’s get a snap of the use bar.
The Panic call is an IRQ event without an ACK. Something is still missing.
by
@danj https://imgur.com/a/VEi3Z1E storage looks fine, not much left (around 43gb) but probably enough
by
@renax - I would run Disk Utility from either the OS recovery Or via an external bootable drive. But do make a full backup before yo do.
by
Add a comment
Well I will suggest you to checkout the following thread: https://support.apple.com/en-in/102356
1 Comment:
That doesn’t address the kernel panics and needing to hold the button down for a long time to start it.
by
Add a comment
With your Panic log "CORE 1 is the one that panicked. Check the full backtrace for details." I think the Logic Board had got fault.
This is the similar case:
https://discussions.apple.com/thread/254...
Add a comment
Add your answer
Renaxツ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 91
All Time: 91
