The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47 Questions View all
airport extreme install not working
eMac 1.25 mhz 1GBram 80GB HD
Hi iFixit Folks!
I'm trying to install a 1026 extreme card but wire for back of card can't be found in my eMac 1.25 ! There is not any wire to connect to the back of card! The card slot is correct and super drive has nothing connected to it? I'm trying to take off the front to see if it's behind it ( with the great tools I bought from you ;-) ! But I get any signal with just the card as it stands now. Any GREAT CLUE from iFixit? Hope so! Thanks.
Michael vega
pslvega@gmail.com
Update
Mr. Mayer
I don't see a cable anywhere so far, but I dont know where it would be stuffed around the front, as I've got the front of the moniter loosened from the back case cover but not free of the metal covering because I was reading about the danger of CRT implosion! Which is not a chance I want to take! I'm the original owner and never put a AP card in it, though I did try to put an original AP card in only to realize it would take only the extreme card. Did apple ever leave out the antennas on these machines? I do have a torn down G3 iBook antenna that is still attached to the LCD moniter only by a soldered end and the microboard attached, could I extact that and attach it to the eMac? If so what would the process be? I don't have any diagram as to where the eMac antenna is supposed to be located from point to point of attachment. If I take the one from the G3 iBook how do I remove it without any damage to it?
I truely appreciate all you advice now and also the past! It has been very enlightening to my issues. I must say though I've bought a Windows PC because of the great price point and find it interesting but the Mac OS is my first love and will always be since 1985! I do plan on making a Mac virtual machine out of the PC. I have 5 EASY Mac's no older than 2005 & iPod Touch 4 gen. and they work well but slow compared to the current Machines. Just a FYI to you! (babble Babble, BABBLE!) Anyway if you have any easy clue on what to do, it as always will be appreciated!
Thanks a Bazillion
Michael
Score 1
1 Comment
Can I trade HD's between the eMac and a G4 1.44mhz Mac Mini?
by
Add a comment
Chosen Solution
Here is a link to Apples installation guide. Hope this helps you find the antenna cable.
http://support.apple.com/kb/HT2596
Score 3
Add a comment
Here's the guide I wrote on doing this: eMac AirPort Card Replacement
The fact that the optical drive is disconnected, leads me to believe someone has been in this machine and moved or removed cables. You may have to open it up further to see what's missing.
Score 3
1 Comment:
The Mac Mini uses a 2.5" PATA drive and the eMac a a 3.5 " PATA hard drive. So you can rig the Mini drive to work in the eMac but you can't fit the eMac drive into the Mini.
by
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,127
