Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25 Questions View all
Where to buy replacement batteries for flip minoHD
Hello I have a couple of flip mino hds that i have taken apart and I have tested all the batteries and they are all dead. When I attach a working battery from different mino it works fine! Anyone know where I can find replacement parts?
I have tried batteries plus and called flip. batteries plus could not find a replacement and flip told me they do not sell replacement batteries for the mino as it is an internal battery.
Please if anyone has any advice it would be greatly appreciated!
3 Comments
It might be possible to replace the battery, but to keep the case and circuit board. Do you have a part number on your battery?
by
Add a comment
Most Helpful Answer
Hi,
I've found a source of the battery (only large quantities from this supplier). Does anyone know how the PCB controller attached to the Flip Mino battery might be reused? The original is spot welded.
I'll bet there are lots of these cameras out there that could be saved if we could figure out how to safely install just a new battery in this recorder.
Here are the data on the battery and it's supplier:
Lithium ion Sanyo 553450 UF553450Z battery cell
Part Number: 0204-0019-00
Model Number: 1UF553450-1-T0423
http://www.alibaba.com/product-gs/349657...
Score 1
Add a comment
Part:http://www.amazon.com/Flip-Video-Ultra-R...
Best of Luck,
3 Comments:
Thanks but this is not the battery for the minoHD.
Does anyone know if it is possible to buy a regular li-ion 3.7 v 1150mAh battery and install the board from the old pack onto it?
by
Unfortunately, that was the only battery on the market. Unless you buy a used or broken one, and transfer the battery, there is no other way to do so.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
by
Battery for Palm One LifeDrive Pocket PC seems to be an equivalent but connector needs to have four leads. Have ordered one and if it is a replacement will report.
by
Add a comment
Any more recent news on battery replacement for a MinoHD? Ours no longer keeps a charge for more than a few minutes.
1 Comment:
EBAY has the internal batteries for the flip
by
Add a comment
I have purchased many of these batteries here http://bestbattery.biz/Cisco/221946-F460...
Add a comment
How do you open minoHD for changing the battery?
Add a comment
If you need cheap and high quality durable camcorder batteries then cheak this http://broadcastbatteries.tv/
Add a comment
This is a direct replacement battery, with the same 4 wire connector!
https://www.amazon.com/gp/aw/d/B00ET08ZK...
Add a comment
Add your answer
ecarter1117 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 32
All Time: 7,886
