Repair guides and disassembly information for laptops manufactured by ASUS.
2579 Questions View all
How do I fix my internet connection?
My Asus laptop is not connecting properly to the internet. It is connected to a network, but when I open Internet Explorer, nothing pops up. It doesn't even tell me it can't display the page, it's just a blank screen. I tried disconnecting and reconnecting to my home network- didn't work. Then I tried turning it off and on againā€”didn't work. Finally, I turned off my router for about a minute and turned it back onā€”my internet explorer is still a blank screen. My Norton subscription just expired yesterday, but I'm not sure if that has anything to do with my internet problemā€”even though the problem began to occur on the day of expiration. Any help you can provide me would be great.
Score 37
16 Comments
Have you tried navigating to a webpage? Have you tried another browser? (Google Chrome: http://goo.gl/jBttB). Do you have any screenshots you might be able to provide?
by
i have an ASUS X550L series laptop and i cant connect to my modem
i just got a new one and it wont connect to it but my other devices can
it says can't connect to this network.
by
i have an Asus X555la series laptop which came with windows 8,after updating to windows 10,, my wireless connection doesn't show at all but my LAN network is working but not the wireless what would be the cause
by
many people are getting this problem . http://goo.gl/5oOELG follow and this will help
by
I just got a new ASUS X550L series and have the same problem as pk lei..please let me know how to connect to our wireless connection! So frustrating.
by
Show 11 more comments
Add a comment
Chosen Solution
Hi,
Go to Control Panel and open Programs and Features to Uninstall Norton from the programs list. Open up Internet Explorer and click on Tools, and then Internet Properties. Go to the Connection tab and click on the LAN Settings button and uncheck all the check boxes. Click OK and restart your computer.
Good Luck.
Score 19
32 Comments:
DAVID! You are so amazing! Thank you sooooo much. No one else helped but you solved my problem like that! Your the real MVP!
by
David, this was exactly my problem also and you solved my problem!!! Thank you so very much!!
by
David - Hi...Just found this site and going through the same issue. Will this work if your dealing with WiFi? Thanks - JW
by
Thanks david...u are awesome!! It works fine!!
by
I don't have Norton, I have McAfee, and I'm still having the same issue, do I uninstall McAfee?
by
Show 27 more comments
Add a comment
Most Helpful Answer
Right Click WiFi Connection Symbol on the bottom right corner of the Desktop
Open Network and Sharing Center
Click on Change Adapter Settings
Right Click the Network Device showing Limited Connectivity
Click Properties
Click on the Configure Button
Click on the Driver Tab
Click on the Uninstall button
Restart computer
Windows Auto Installs the Driver
Reconnect to router
Problem Solved
Score 27
15 Comments:
Omg!!! Thank you so much!! It fixed!
by
I tried this and now my window is not auto installing this . Now I don't have wifi option
by
It got fixed. Thank you so much.
by
Worked perfectly, thanks!
by
update the wireless driver for steps follow post http://fixingblog.com/asus-laptop-wirele... see if this works
by
Show 10 more comments
Add a comment
At first you should check your Internet connection. Have it plugging properly or not. Then you check configuration setting and open your IE.
Go to Tools>Internet Options>Connections tab
Go to LAN settings.
And adjust "Automatically detect settings"
Also go to the advance tab and click the Restore Advance Settings button or you can reinstall your IE.
Score 3
5 Comments:
AWESOME! I got it working thanks(:
by
I tried this and it didn't work. I also restarted and I am not able to get the internet page up. Even though I have a strong connection and the internet works on all other devices.
by
when I pressed "Automatically detect settings" the advance tab don't come up. it says I have to press the "use proxy server for your LAN". now what shell I do? shell I tick the Proxy box??? please answer my Question.
by
thank you so much. my laptop is working now because I uninstalled the MacAfee. But still I am little bit worried about is it going to affect my laptop by allowing some viruses.
by
Osum !!! This worked.. Thanks a lot !!!
by
Add a comment
what is the problem when i open the laptop ASUS Windows 8 and also the page internet explorer open at once , and i want not to open it , please explain for me the problem
Score 1
Add a comment
This works again. Thanks David!
Score 1
Add a comment
Network card problem pƄ found in configuration panel
Score 1
Add a comment
Hello!
I have the same problem woth wifi. My ASUS is connected to internet but does not navigate, etc.
This happens everywhere, and my phone connects to these wifi without issues.
Can you help me out? Already tried
- Rebooting
- Deactivate, activate laptop router
- Disabling power option from the adapter.
- Uninstalling adapter and reinstalling after reboot
Thanks
Score 1
Add a comment
Maybe it's the Power Management of the network adaptor. See the 5th post of this link: http://www.sevenforums.com/network-shari...
Add a comment
Try to download FixR 2.0, it can do this steps automatically, no technical skill required. Link to download http://fixr2.com
Add a comment
In Portuguese
A mim resultou desta forma
Painel de controlo
Rede e Internet
LigaƧoes de Rede
Click botao direito em Wi-Fi - DESATIVAR
Reiniciar o Computador
Voltar ao mesmo local em LigaƧoes de Rede e em Wi- Fi- ACTIVAR
Boa sorte,
phil
Add a comment
Had the same issues and wasn't finding success with the other answers. Found success this way: CTRL+ALT+DEL to pull up Task Manager. Go to the startup tab and disable Intel(R) Security Assist. Connected immediately. Good luck.
Add a comment
My asus laptop stated that it has connected to wifi. However my spotify and other website stated there is no connection to internet. My laptop is Asus Vivobook, Intel Core i5 8th Gen.
Add a comment
Add your answer
Cecelia Zitarosa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 333,995
