MacBook Air 13" Late 2020 USB-C Board Replacement
  1. MacBook Air 13" Late 2020 USB-C Board Replacement, Remove the screws securing the lower case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 USB-C Board Replacement, Remove the lower case: step 2, image 1 of 3 MacBook Air 13" Late 2020 USB-C Board Replacement, Remove the lower case: step 2, image 2 of 3 MacBook Air 13" Late 2020 USB-C Board Replacement, Remove the lower case: step 2, image 3 of 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 USB-C Board Replacement, Disconnect the battery: step 3, image 1 of 3 MacBook Air 13" Late 2020 USB-C Board Replacement, Disconnect the battery: step 3, image 2 of 3 MacBook Air 13" Late 2020 USB-C Board Replacement, Disconnect the battery: step 3, image 3 of 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 USB-C Board Replacement, Disconnect the USB-C board: step 4, image 1 of 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 USB-C Board Replacement: step 5, image 1 of 1
    • Remove the USB-C connector cover.
  6. MacBook Air 13" Late 2020 USB-C Board Replacement: step 6, image 1 of 2 MacBook Air 13" Late 2020 USB-C Board Replacement: step 6, image 2 of 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  7. MacBook Air 13" Late 2020 USB-C Board Replacement, Remove the USB-C board: step 7, image 1 of 1
    • Use a T5 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
  8. MacBook Air 13" Late 2020 USB-C Board Replacement: step 8, image 1 of 2 MacBook Air 13" Late 2020 USB-C Board Replacement: step 8, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the USB-C board.
Once you've completed your repair, your laptop may not power back on until connected to power.
25 other people completed this guide.
Carsten Frauenheim
115,421 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
18 Comments
This guide was excellent. Easy & painless, even though it was the most complex repair I've taken on myself. Thanks for saving time & money.
Zachary Barber - Reply
Do you sell the screws for the usb c board? I have lost one of the 1.4mm torx screws which hold down the connector of the usb board.
Gurmeet Sahotay - Reply
This was quite easy, thanks so much Carsten!
Michael C Crotty - Reply
where can I get the part for my computer MacBook Air M1 2020 Usb-C connector model A2337 EMC 3598 serial CO2FN1R2Q6LC.
Where can I buy it online....
Resana Laucast - Reply
If you're in selected countries in Europe or the USA, you can now order this part from Apple directly using their Self Service Repair store :)
Alex Firth -
Past 24 Hours: 29
Past 7 Days: 343
Past 30 Days: 1,588
All Time: 35,983
