MacBook Pro 13" Touch Bar 2017 Battery Replacement
  1. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disable Auto Boot: step 1, image 3 of 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the pentalobe screws: step 2, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Open a gap using a suction cup: step 3, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Open a gap using a suction cup: step 3, image 2 of 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the clips: step 4, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the clips: step 4, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the clips: step 4, image 3 of 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 5, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 5, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 5, image 3 of 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 6, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 6, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 6, image 3 of 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 7, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 7, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 7, image 3 of 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the lower case: step 8, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the lower case: step 8, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the lower case: step 8, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Uncover the battery connector: step 9, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Uncover the battery connector: step 9, image 2 of 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 10, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 10, image 2 of 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 11, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 11, image 2 of 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  12. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 12, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 12, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 13, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 13, image 2 of 2
    • Fold the battery board data cable to the side and out of the way.
  14. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 14, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 14, image 2 of 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the battery: step 15, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the battery: step 15, image 2 of 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  16. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad connector screws: step 16, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad connector screws: step 16, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  17. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 17, image 1 of 1
    Buy
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  18. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the trackpad: step 18, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the trackpad: step 18, image 2 of 2
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  19. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Heat the trackpad cable: step 19, image 1 of 1
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  20. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the trackpad cable: step 20, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the trackpad cable: step 20, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the trackpad cable: step 20, image 3 of 3
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  21. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad screws: step 21, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad screws: step 21, image 2 of 2
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  22. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 22, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 22, image 2 of 2
    • Swing the display open slightly to access the trackpad.
    • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
  23. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad: step 23, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad: step 23, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the trackpad: step 23, image 3 of 3
    • Remove the trackpad assembly.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
  24. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the keyboard connector screws: step 24, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the keyboard connector screws: step 24, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket.
  25. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 25, image 1 of 1
    • Remove the keyboard connector bracket.
  26. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the keyboard: step 26, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the keyboard: step 26, image 2 of 2
    • Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board.
  27. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the display board: step 27, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the display board: step 27, image 2 of 2
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  28. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 28, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 28, image 2 of 2
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  29. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 29, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 29, image 2 of 2
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  30. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Thunderbolt port screws: step 30, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Thunderbolt port screws: step 30, image 2 of 2
    • Using a T3 Torx driver:
    • Remove two 1.4 mm screws from the Thunderbolt port connector bracket on the left.
    • Remove two more 1.4 mm screws from the Thunderbolt port connector bracket on the right.
  31. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left Thunderbolt ports: step 31, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left Thunderbolt ports: step 31, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left Thunderbolt ports: step 31, image 3 of 3
    • Use a spudger to disconnect the left-side Thunderbolt port connector by prying it straight up from the logic board.
    • Pry from the inside edge, nearest the fan.
    • Gently push the connector aside so it won't interfere with logic board removal.
  32. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right Thunderbolt ports: step 32, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right Thunderbolt ports: step 32, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right Thunderbolt ports: step 32, image 3 of 3
    • Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside.
  33. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch ID connector screws: step 33, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch ID connector screws: step 33, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors.
  34. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 34, image 1 of 1
    • Remove the bracket.
  35. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the headphone jack: step 35, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the headphone jack: step 35, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the headphone jack: step 35, image 3 of 3
    • Use a spudger to disconnect the 3.5 mm audio jack flex cable by prying it straight up from the logic board.
    • Gently push the flex cable aside.
  36. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect Touch ID: step 36, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect Touch ID: step 36, image 2 of 2
    • Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board.
  37. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Heat the Touch ID cable: step 37, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Heat the Touch ID cable: step 37, image 2 of 2
    • Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable.
  38. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Pry up the Touch ID cable: step 38, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Pry up the Touch ID cable: step 38, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Pry up the Touch ID cable: step 38, image 3 of 3
    • Carefully slide an opening pick under the flex cable to separate it from the logic board, and push it carefully aside.
    • Be very careful not to damage this delicate flex cable. The attached Touch ID sensor is uniquely paired to your MacBook's logic board—if damaged, only Apple can successfully replace it.
    • If you have trouble, don't force it—apply a little more heat and try again.
  39. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch Bar digitizer screw: step 39, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch Bar digitizer screw: step 39, image 2 of 2
    • Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket.
  40. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 40, image 1 of 1
  41. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the Touch Bar digitizer: step 41, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the Touch Bar digitizer: step 41, image 2 of 2
    • Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board.
  42. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch Bar display screws: step 42, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the Touch Bar display screws: step 42, image 2 of 2
    • Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket.
  43. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 43, image 1 of 1
  44. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the Touch Bar display: step 44, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the Touch Bar display: step 44, image 2 of 2
    • Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board.
  45. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Uncover the microphone connector: step 45, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Uncover the microphone connector: step 45, image 2 of 2
    • Peel back any tape covering the microphone connector socket.
  46. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the microphone: step 46, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the microphone: step 46, image 2 of 2
    • Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
  47. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 47, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 47, image 2 of 2
    • Disconnect the microphone cable by pulling it back—away from the fan—until it slides out of its socket.
    • If possible, pull on the attached tape, rather than on the cable itself.
  48. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 48, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 48, image 2 of 2
    • Peel back any tape covering the connector for the left-side tweeter.
  49. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left tweeter: step 49, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left tweeter: step 49, image 2 of 2
    • Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board.
  50. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 50, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 50, image 2 of 2
    • Disconnect the cable by pulling it towards the tweeter until it slides out of its socket.
    • If possible, pull on the attached tape rather than the cable itself.
  51. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 51, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 51, image 2 of 2
    • Underneath the tweeter's flex cable lies a second ZIF connector, for the left main speaker.
    • Peel back any tape covering the socket for the left main speaker.
  52. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left main speaker: step 52, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the left main speaker: step 52, image 2 of 2
    • Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board.
  53. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 53, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 53, image 2 of 2
    • Disconnect the left main speaker cable by pulling it toward the tweeter until it slides free from its socket.
    • Remember to pull on the attached tape, not the cable.
  54. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 54, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 54, image 2 of 2
    • Repeat the previous six steps to disconnect the opposite tweeter and main speaker, on the right.
    • Begin by peeling back any tape covering the tweeter connector.
  55. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right tweeter: step 55, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right tweeter: step 55, image 2 of 2
    • Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board.
  56. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 56, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 56, image 2 of 2
    • Remember to pull on the tape if possible—not the actual cable.
  57. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 57, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 57, image 2 of 2
    • Peel back any tape covering the connector for the right-side main speaker.
  58. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right main speaker: step 58, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the right main speaker: step 58, image 2 of 2
    • Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board.
  59. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 59, image 1 of 1
    • Pull the right-side main speaker cable toward the tweeter until it slides free from its socket.
  60. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the antennas: step 60, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the antennas: step 60, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Disconnect the antennas: step 60, image 3 of 3
    Buy
    • Disconnect the first antenna cable by prying it straight up from its socket.
    • Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
  61. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 61, image 1 of 1
    • Repeat the previous step to disconnect the two remaining antenna cables.
    • To reconnect each cable, align the connector directly over its socket, and then press down to snap it into place.
  62. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the antenna bundle screw: step 62, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the antenna bundle screw: step 62, image 2 of 2
    • Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle.
  63. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Unscrew the logic board: step 63, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Unscrew the logic board: step 63, image 2 of 2
    • Remove all ten screws securing the logic board assembly:
    • Three 2.5 mm Torx T3 screws
    • Five 2.9 mm Torx T5 screws
    • Two 3.0 mm Torx T5 screws
    • During reassembly, install these screws loosely and adjust the logic board's position if necessary before tightening the screws.
  64. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the fan dampers: step 64, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the fan dampers: step 64, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Peel up the fan dampers: step 64, image 3 of 3
    • Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
    • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
  65. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the logic board assembly: step 65, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the logic board assembly: step 65, image 2 of 2
    • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
    • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
    • Lift from the left side to remove the logic board assembly.
  66. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Logic board installation: step 66, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Logic board installation: step 66, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Logic board installation: step 66, image 3 of 3
    • When reinstalling the logic board assembly:
    • Check the alignment of the rubber vibration dampers, and adjust them as needed.
    • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
  67. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Unscrew the battery board: step 67, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Unscrew the battery board: step 67, image 2 of 2
    • Use a T5 Torx driver to remove the two 3.2 mm screws from the battery board.
  68. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect the display and keyboard: step 68, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect the display and keyboard: step 68, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect the display and keyboard: step 68, image 3 of 3
    • The liquid adhesive remover provided in your kit can cause damage if it contacts the MacBook Pro's display or keyboard.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use some tape and/or foil to seal off the area under the trackpad. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
  69. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect the speakers: step 69, image 1 of 1
    • Before removing the battery, it's important to protect the speakers on either side. The speakers are glued down just like the battery—so if the liquid adhesive remover gets under the speakers, they may come loose and rattle after your repair.
    • Cut a length of packing tape or painter's tape, and slide one edge between the battery and the speaker on the left side.
  70. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 70, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 70, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 70, image 3 of 3
    • Press all along the edge of the tape with your spudger to stick it securely to the MacBook Pro's aluminum case, sealing off the speaker from the battery.
    • Be careful not to poke or puncture the battery.
    • Fold the tape over and lightly adhere it to the speaker to keep it out of the way.
    • The foam bumpers on top of the speaker may tear when peeling the tape off. Don't press the tape directly onto the bumpers.
  71. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 71, image 1 of 1
    • Repeat the previous two steps on the opposite side in order to seal off the other speaker from the battery.
  72. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the right edge: step 72, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the right edge: step 72, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the right edge: step 72, image 3 of 3
    • To control the flow of adhesive remover and direct it away from the speaker, raise the right edge of your MacBook Pro a few inches using a book or foam block.
  73. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect your eyes and skin: step 73, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Protect your eyes and skin: step 73, image 2 of 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  74. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Open the adhesive remover: step 74, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Open the adhesive remover: step 74, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Open the adhesive remover: step 74, image 3 of 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  75. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply the adhesive remover: step 75, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply the adhesive remover: step 75, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply the adhesive remover: step 75, image 3 of 3
    • Apply a few drops of adhesive remover underneath the far right battery cell.
    • You don't need to use very much—the small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait about two minutes for the adhesive remover to penetrate and soften the battery adhesive before you proceed to the next step.
  76. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the outside right battery cell: step 76, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the outside right battery cell: step 76, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the outside right battery cell: step 76, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • After a couple minutes, insert one corner of a plastic card underneath the far right battery cell, starting from the front edge.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way under the battery cell.
    • Lift to fully separate the adhesive, but don't try to remove the battery cell yet.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
  77. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Alternative: separate the battery cell with floss: step 77, image 1 of 1
    • If you have difficulty getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell. Pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
  78. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the left edge: step 78, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the left edge: step 78, image 2 of 2
    • Repeat the last few steps to separate the far left battery cell.
    • Begin by elevating the left side of the MacBook Pro to direct the flow of adhesive remover away from the speaker.
  79. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 79, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 79, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 79, image 3 of 3
    • Apply a few drops of adhesive remover under the far left battery cell, and wait about two minutes for it to penetrate.
  80. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the outer left cell: step 80, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the outer left cell: step 80, image 2 of 2
    • Slide one corner of a plastic card underneath the far left battery cell, and carefully separate the adhesive holding it in place.
  81. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the back edge: step 81, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Elevate the back edge: step 81, image 2 of 2
    • Next, raise the back edge of your MacBook Pro to direct the flow of adhesive remover away from the keyboard/logic board area.
  82. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 82, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 82, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Apply adhesive remover: step 82, image 3 of 3
    • Apply a few drops of adhesive remover under each of the remaining three battery cells.
    • There are openings in the aluminum case underneath these cells, so some of the adhesive remover may leak out instead of penetrating underneath the battery.
    • Be mindful of leaks, and apply more adhesive remover in the following steps if needed.
    • Wait about two minutes before you continue.
  83. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner left cell: step 83, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner left cell: step 83, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner left cell: step 83, image 3 of 3
    • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
    • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
  84. MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 84, image 1 of 2 MacBook Pro 13" Touch Bar 2017 Battery Replacement: step 84, image 2 of 2
    • Use your plastic card to fully separate the remaining battery cell on the left side.
    • Leave your plastic card in place temporarily to prevent the left-side battery cells from re-adhering.
  85. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner right cell: step 85, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner right cell: step 85, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the inner right cell: step 85, image 3 of 3
    • Repeat the previous two steps to separate the remaining battery cell on the right.
  86. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the middle cell: step 86, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the middle cell: step 86, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Separate the middle cell: step 86, image 3 of 3
    • The final battery cell can be more difficult to remove. If needed, apply more adhesive remover to make the job easier.
    • Slide the corner of one of your plastic cards underneath the top edge of the large center battery cell.
    • Wiggle the card from side to side and slide it underneath the battery cell to fully separate the adhesive holding it in place.
  87. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the battery: step 87, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the battery: step 87, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Remove the battery: step 87, image 3 of 3
    Buy
    • Remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
    • When you're done, carefully remove the protective tape from the speakers.
  88. MacBook Pro 13" Touch Bar 2017 Battery Replacement, Battery installation: step 88, image 1 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Battery installation: step 88, image 2 of 3 MacBook Pro 13" Touch Bar 2017 Battery Replacement, Battery installation: step 88, image 3 of 3
    Tesa 61395 Tape
    $10.99
    Buy
    • Double-check the fit and alignment of your new battery before sticking it down.
    • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
82 other people completed this guide.
Jeff Suovanen
429,028 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
38 Comments
Amazing, Thanks
suelectronico - Reply
does this also work for the 2018 model?
Κυριακος Καρυος - Reply
Why do you remove the logic board? There are videos on youtube that demonstrate that there is no need to remove the logic board or the trackpad to replace the battery ...
Elio Deinase - Reply
no need to remove the logic board .
Cosmin -
Just finished replacing - stopped at step 23 after removing the Track Pad. Did not have to remove Logic Board. You don’t even need to remove the Track Pad, but because of the glue on the center cell, it’s probably a good idea and a pretty easy step to keep Track Pad safe when prying the cell off the case. It does take a bit of careful “jiggling” to remove the old battery and to slide the new one under the LB, but IMO definitely much (MUCH!) easier than removing all of the components after step 23.
Vadique -
Past 24 Hours: 79
Past 7 Days: 628
Past 30 Days: 3,060
All Time: 184,608
