Philips Sonicare FlexCare Shaft Replacement
  1. Philips Sonicare FlexCare Shaft Replacement, Shaft: step 1, image 1 of 1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Shaft Replacement: step 2, image 1 of 1
    • Have a look to an alternative opening procedure.
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
  3. Philips Sonicare FlexCare Shaft Replacement: step 3, image 1 of 2 Philips Sonicare FlexCare Shaft Replacement: step 3, image 2 of 2
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Shaft Replacement: step 4, image 1 of 1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Shaft Replacement: step 5, image 1 of 1
    • Using a #00 phillips head screwdriver, loosen the screw completely.
  6. Philips Sonicare FlexCare Shaft Replacement: step 6, image 1 of 1
    • Rotate the interior of the toothbrush until the screw is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
    • Slightly shake the interior so that the screw falls out.
    • A small ring may fall out when the screw is removed. Be careful not to lose the ring.
  7. Philips Sonicare FlexCare Shaft Replacement: step 7, image 1 of 1
    • Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
    • A small nut may fall out when the shaft is removed. Be careful not to lose the nut.
  8. Philips Sonicare FlexCare Shaft Replacement: step 8, image 1 of 1
    • Once the shaft is released, separate it from the body of the interior.
    • Insert the replacement shaft by aligning the the components and applying a force to insert the legs (one of the legs is identified by the red arrow) of the shaft into the interior.
47 other people completed this guide.
Tasha Panattoni
766 Reputation
2 Guides authored
Cal Poly, Team 4-6, Maness Spring 2015 Member of Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Members
23 Guides authored
37 Comments
Where do you get a replacement shaft? I can't find any online
noahmckinnon - Reply
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
jelneutron3 - Reply
I can not find the shaft anywhere who sells them
bennie - Reply
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
Lino Valadas - Reply
Like everyone above, I can't locate the "replacement shaft". Anyone have any ideas who might have one? A $179 toothbrush should last more than the one year warranty! Is the Braun Oral-B any better?
pgootos - Reply
Past 24 Hours: 118
Past 7 Days: 755
Past 30 Days: 3,625
All Time: 231,393
