Frigidaire Dishwasher Troubleshooting: Fix Common Problems
The first step towards a working Frigidaire Dishwasher is identifying the problem. Select one of our preferred guides below to diagnose and solve Frigidaire Dishwasher common issues.
Frigidaire Dishwasher Not Starting
Frigidaire dishwasher won't power on? Try these fixes.
Frigidaire Dishwasher Not Draining
Is your Frigidaire dishwasher full of water at the end of your wash cycle? Is water leaking out onto the floor? Try these fixes.
Related Dishwasher Problems
Is your dishwasher full of water at the end of your wash cycle? Is water leaking out onto the floor? Try these fixes.
Dishwasher Soap Pods Not Dissolving
When dishwasher soap pods don't dissolve, the dishes inside will remain dirty. Let's figure out the issue and make your glasses shine again.
Dishwasher Leaking
If you're experiencing pools of water on the ground, especially from the bottom of the door, your dishwasher is losing water.
Dishwasher Not Cleaning
When you dishwasher stops washing the dishes, it has become obsolete. Follow this troubleshooting guide to get your machine running again.
Dishwasher Won't Turn On
Dishwasher won't power on? Try these fixes.
Dishwasher Stops Mid Cycle
Dishwasher stopped working or turned off mid cycle? Try these fixes.
Dishwasher Not Drying
What to do when your dishes aren't dry at the end of a wash cycle? Try these fixes first.
Having a dishwasher malfunction can be frustrating, but often, the issues you encounter can be solved with some simple troubleshooting. This guide is designed to help you identify and resolve common problems with your dishwasher right at home. Whether you're dealing with a dishwasher that won't start, isn't cleaning properly, or has a leak, our straightforward steps will assist you in diagnosing and fixing the issue.
Dishwasher Smells Bad
Pee-ew — Dishwasher leaving your kitchen smelly after a load? Follow this troubleshooting guide to solve problem of musty, fishy, or other gross smells from your machine.
Dishwasher Won't Drain
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
There is a 1 to 2 inches of water left after cycle ends.
Dishwasher cycle times change almost daily
Dishwasher fills with water and then turns OFF!
Door does not know if it's open or closed
Problems with a Frigidaire Dishwasher
Frigidaire Gallery dishwasher fgip2468uf
How do I check for a short in my dishwasher
frigidaire gallery dishwasher flashing Cd even after I replaced the la
