Samsung Refrigerator Troubleshooting: Fix Common Problems
The first step towards a working Samsung Refrigerator is identifying the problem. Select one of our preferred guides below to diagnose and solve Samsung Refrigerator common issues.
Samsung Refrigerator Beeping
Your Samsung Fridge may beep for a number of reasons, Let's try these fixes to solve the noise.
Samsung Freezer Not Freezing
Is your Samsung fridge cold but the freezer compartment is warm? Follow these fixes to get your freezer freezing again.
Samsung Ice Maker Not Making Ice
Does your Samsung ice maker fail to make cubed or crushed ice, but still dispenses water? Try these fixes first so you can reset your machine and get back to chillin'.
Samsung Refrigerator Not Cooling
Is your Samsung fridge warm but the freezer is cold? Maybe the refrigerator isn't cold enough? Follow these fixes to get your refrigerator cooling again.
Samsung Refrigerator Forced Defrost Mode
You need to run a forced defrost, but you need to find the right buttons to push. This will show you how.
Samsung Ice Maker Leaking
If your Samsung ice maker leaks fluid, follow this problem page so you can get back to chillin.
Samsung Refrigerator Tripping GFCI
Is your fridge plugged into a GFCI-protected outlet? Is it losing its cool because it loses its power? Let's look at solutions!
Samsung Refrigerator Not Cooling But Freezer Works
Your fresh food compartment (refrigerator) isn't cooling, but the freezer seems to work. Let's get you back to cooling all around.
Samsung Refrigerator Making Humming Noise
Your Samsung refrigerator is humming but doesn't sound like a good tune. Let's start a new song.
Samsung Refrigerator Door Not Closing
Your fridge doors won't close. You don't want to cool your home with your fridge. Let's shut things up!
Related Refrigerator Problems
Refrigerator Compressor Not Running
Has your refrigerator lost its cold? Is the compressor running while power is on? Follow these fixes to get your fridge's most important component working again.
Refrigerator Compressor Running but Not Cooling
Refrigerator Light Flickering
Are your fridge LEDs blinking or flashing? Is your door light flickering? Follow these fixes to resolve the light.
Does your fridge keep tripping the GFCI or circuit breaker? Whether it trips immediately or after a few hours, follow this fixes to get your refrigerator working again.
Fridge Not Cooling But Freezer Works
Is your fridge warm but the freezer is cold? Maybe the refrigerator isn't cold enough? Follow these fixes to get your refrigerator cooling again.
Refrigerator Making Knocking Noise
Is your fridge making intermittent knocking sounds, clunking, or banging sounds? Sounds like your fridge wants to be a musician! Follow these fixes to return your refrigerator to working its day job.
Ice Maker Leaking
If your ice maker leaks fluid, follow this problem page so you can get back to chillin.
Freezer Ice Building Up
Is your freezer compartment full of ice cubes? Are the shelves coated in powdered snow or ice crystals? Follow these fixes to defrost your freezer.
Does your ice maker fail to make cubed or crushed ice, but still dispenses water? Try these fixes first so you can reset your machine and get back to chillin'.
Ice Maker Not Dispensing Ice
If your ice maker isn't dispening ice, follow this problem page so you can get back to chillin.
Is your fridge cold but the freezer compartment is warm? Follow these fixes to get your freezer freezing again.
Refrigerator Leaking Water
Is a pool of water forming underneath, inside, or behind your fridge? Follow these fixes to stop your refrigerator or freezer from leaking.
Is your fridge door not closing properly? Will food not stay cold because of a seal issue? Follow these fixes to get your food cold again.
Freezer Not Freezing Ice Cream
Is your freezer cold, but not cold enough to make the ice cream solid? Try these fixes to drop your refrigerator temperature.
Refrigerator Makes Humming Noise
Is your refrigerator humming? Does it hum constantly, or stop frequently? Follow this fixes to discover what's going on with your fridge.
Ice Maker Won't Stop Making Ice
Is your ice maker running? Is it uncontrollably overfilling with ice? Read this troubleshooting guide to catch and stop the ice before you're underwater!
Refrigerator Has Freezer Leaking Water Into Fridge
The Freezer is dripping into the fridge. What a mess! Let's get the leak stopped and things flowing normally.
Ice Maker Only Crushing Ice
If your ice maker is only crushing ice and not dispensing cubes, follow this problem page so you can get back to chillin.
Ice Maker Making Hollow, Small, or Mushy Ice Cubes
Are your ice cubes small, hollow, or mushy? Does your ice maker usually make solid ice cubes? Follow these fixes and get consistent ice again.
Refrigerator Won't Dispense Water
If your fridge isn't dispensing water while the ice maker dispenses ice, follow these fixes to get your water flowing again.
Refrigerator Sounds and Possible Causes
Here's a list of sounds or noises you might hear and some common causes.
Ice Maker Making Cloudy Ice Cubes
Is your ice cloudy? Are there specks of dirt or debris in your ice cubes? Follow the fixes below to start making clean and clear ice again.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Ice Build-Up in Back Wall
Samsung Refrigerator RF28HDEDT
Ice is not dropping into receptical
Samsung Refrigerator RS261MD**
Water stopped getting dispensed from refrigerator, all of a sudden :(
Samsung Refrigerator RF4287HA**
Ice Maker Stopped Dumping Ice
Samsung Refrigerator RF261BEAE**
It makes ice, dumps into the bucket but will not dispense.
Samsung Refrigerator RS25J500D**
Why the light at frieze and fridge it’s blinking and not keeping cold
Every 3 weeks our refrigerator fan freezes and starts making noise,
Cooling problem with refrigerator
Samsung Refrigerator RS265TD**
